Old 10-11-2008, 05:39 PM   #3
EthanMKIII
EthanMKIII is on a distinguished road
Originally Posted by Busted Knuckles View Post
The VSS is in the speedometer. Does your speedo work? Is the speedo cable broken? If everything else is OK, the speedo cluster will need to come out, and the VSS module checked out. I've never done this, but I grabbed a spare cluster from a parts car just in case I have problems with mine.
Ya it works perfectly fine. The only problem is that the rad light stays on, i even put a new rad in and it still does it so i think the lights just broken.
I put bigger rims than stock on the car would tha affect it?
EthanMKIII is offline   Reply With Quote
