7mgte swap ?
I have an 86.5 n/a 5speed i want to do a gte swap in looking at a 91 gte just want to know if it will bolt in, not sure about the mounts? Also the harness and ecu need to be the same your as the car or the motor any info helps please let me know thanks. Trying to figure out if it will all work before i buy the motor.
the only ? is will the 91 motor fit in my 86.5? or ar the mounts different? i dont want to buy the motor and not be able to use it.
ALL BOOST NO JUICE!
In need of some 7mge parts, let me know what you got.
