Old 10-14-2008, 10:20 PM   #2
OkieRA29
OkieRA29 is on a distinguished road
Check your fuses first. Then check the lines to the starter. Should be one bolted on and one that plugs in. Check the battery with a voltmeter. Sometimes you will have enough juice to run stuff, but not enough to crank. Check the connections at the battery. This happened with my wife's camry. Turned out the battery terminals were a tad loose. Start with the fuses and go from there.
OkieRA29 is offline   Reply With Quote
