Most likely, it is that third cam cover/gasket. I would just follow the advice in the 'oil on top' thread. I did that and it solved the problem. To get rid of the oil, I just pulled the plugs and let it drain into the engine. Then I started the car and just burned off the oil. Kind of smokey, but it worked
