oil in your intake tract in no good at all,there may either be a failed turbo oil seal,or just as bad a blown head gasket or really bad valve seals.if there is oil in the intake,check the oil for water also inspect the oil as it is drained from the pan.it will be easy to tell if there is water in the oil , it will look like light mixed milk chocolate if there is alot of water mixed in.if this is so then a leaking valve seal or a blown head gasket may be your problem.look in the radiator and see if there is oil in the coolant too ,if this is tru it is most prone to be a hg.thats all i got,good hunting!
