there are bigger and more oil squirters in the turbo engine,this is one of the factors that make the 2jz-gte so damn dependable,just get the turbo engine and save youself the aching headache that getting a n/a block and pressing these in would cause,other than that and the compression deal, the block is vitually the same as the turbo big brother.there are also 2jz-ge conversion to turbo kits available from suprastore and the like.but these will only yeild around 500hp max potential,with the 2jz-gte the hp can climb to as much as 1200 hp!think these figures over,as 500hp is nothing to scoff at either,peace!
