Carfanatic89
I missed the thread where you gave me the parts info. Thank you very much. I understand your situation. I wish you the best. One of the days I hope to see a thread telling us you got your supra running great.
If you think it may sit for a long time you may want to lubricate the the cam, valves and pistons with Marvel Mystery Oil or some similar lubrrcant. Turnig the engine over manually by using the the harmonic balancer bolt would be helpful too. The lubricant will help prevent problems like I have currently, two stuck valves in the number one cylinder. I lubed everything but I was busy and let it set too long withyout lubing the cam followers.
I wish the best.
Dan Swanson
