Old 11-03-2008, 10:21 AM   #2
Busted Knuckles
Busted Knuckles's Avatar
The clutch master cylinder can leak into the inside of the car. I have a nice stain on my rug under the floor mat due to a leak like that. The master cylinder is a royal PITA to replace. The nut on the left side, near the fender wall, is tricky to get to. I couldn't see mine, and had to put a socket on it blind. Getting it back on is the hardest. I actually lost the original nut somewhere under the dash, and had to use a replacement.
And, if your still running on original hoses, your lucky more haven't blown out. Plan a day to flush out the cooling system and replace the heater hoses. You'll be glad you did.
