Old 11-04-2008, 02:23 AM   #3
Busted Knuckles
Busted Knuckles's Avatar
Sounds like a bad alternator. When mine went bad, battery light and brake light both came on. Radiator light means the coolant reservoir is low. double check it. Check the alternator by putting a volt meter to the battery terminals. If you don't get 13.5 to 14.5 volts, alternator is probably bad. Have it tested.
