You are better off doing the swap. I have an NA and looked into doing the same thing. It's a long, tedious, time and money consuming process. The NA engines (7MGE) don't have a lot of internal components that the turbo engines (7MGTE) do. If I ever want a turbo in my NA, I will do a swap. If you want a turbo engine, check out Jazz Pro Parts. They have the 7MGE, 7MGTE, 1JZ, and 2JZ engines.
