it is quite normal to find a little bit of oil in your intake pipe and intercooler pipes.... if there is bucketloads.. k you have problems heh
now.. pulling trans with engine
that depends on how big your hands are... and if you have an engine hoist that goes high enuf heh
personally... i unbolt the trannie from the engine, unplug ecu, pull it thru to engine.. pull engine
i would say you've thrown a rod bearing.... so drop the sump (oil pan) and have a look to see whats in the bottom.... (don't forget to drain the oil first :P)
Pics of my build.
Do a diagnostic first!
