Old 11-14-2008, 08:36 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by nvr2lo88 View Post
Okay Now Maybe I'm Not Asking The Right Question Or I Am Way Off Base But I Have A 88 Gmc S-15 Same Thing As A Chevy S-10 And I Want To Install A 2jz Or 1jz Motor I Can Get The Motor Tranny Ecu And Full Engine Harness But How Can I Get It To Work What Will I Have To Do I'm Mind Is Blocked This Is My First Engine Swap Like This And I Can Not Wrap My Head Around It So Please Help Me Open To Any Suggestions And Comments Do I Need To Get A Wiring Harness Converter Nobody Even Makes On I Know Of Or I Was Thinking Of Changing The Dash But Not Right Away So Please Get Me Out Of This Jam You Can Also E-mail Me At nvr2lo88@yahoo.com Thank You
I can help you with the 2jz-gte part, but I have no idea what to do aout the S-15.
You can control the 2jz-gte with an mkiv supra turbo wiring harness and either an oem mkiv tt ecu, or an AEM ecu. I'm fairly certain that you'll have to do lots of custom wiring to "adapt" the oem mkiv supra turbo wiring harness to your S-15...either that, or just mount the 2jz-gte ecu inside the engine bay and give it lots of heat shielding, etc. For more info on the mkiv tt oem ecu, there's always the TSRMs.
If you have any more 2jz-gte questions aspect of your project, please feel free to ask - I'll do my best.
Life begins at 30psi.
pwpanas is offline
