If you just want to go fast, and your father is experienced with Chevy engines, then talk to him about a 350 SB or LS2 or something. That is the easiest way to go fast in almost anything.
Not to insult you, but if you feel like doing the proper research and actually learn what would be needed for a 2JZ swap then you can do it. As said before, there is a lot of things that need to be changed to put a 2JZ in a MA70 Supra.
At any rate, good luck.
"Stuck in the 80's"
