thank you for replying to my thread first off, and i did swap the wiring harness and ecm, and MAF, coil packs ignition , cam positioning sensor, intake, fuel rail with turbo injectors cam covers for the coil packs, everything that had to be swapped is swapped over off the other car. Right now i am leaning to maybe my timing is completly off but not sure because all we did was take the distrubuter out and put the cam positioning sensor in we did not alighn anything so i am going to try and see if it's the timing thanks again for replying
