Thread: ECU question
Old 11-28-2008, 06:30 AM   #10
Boombastic
Boombastic is on a distinguished road
Originally Posted by dieseltech24179 View Post
hey guys sorry to but in but im having an ecu problem as well
when i bought my supra the guy said that when he bought it it had a wiring harness for an automatic 7mgte and the car is a manual 7mgte he replaced the wiring harness with the right one but idk if the ecu is the same and theres three of them in the car does anyone have the part number of the ecu from a 7mgte manual ecu...i wouldnt know how to tell them apart
The ecu's aren't the same. The main ecu should be a silver box and should be the biggest one under the passenger side dash, should also have yellow connectors attached to it. The other comps are smaller and I think most of them are black. I would say that the auto ecu would work, but I am not sure since you said that the guy before replaced the harness to a standard harness. So having that done may mean that you need the standard ecu. Cheers.
Boombastic is offline   Reply With Quote
