Well, on my N/A I had a similar problem. Ignition timing was off (Distributor 180 out). I know that the 7MGTE uses a Cam Position Sensor and Coil Packs instead of a distributor, but maybe your CPS is out of alignment, causing it to occasionally fire on the exhaust stroke.
Hope this gives you something to look at and hopefully fix
