Old 12-04-2008, 01:22 AM   #2
ghost88
ghost88's Avatar
ghost88 is on a distinguished road
Default all i can say is...
i know that head gaskets are a common problem for supras because of factory torque settings being to low and head gaskets being cheap or old.
replace anything old - water pump/thermostat/head gaskets then try
again. if problem persists i read on another forum that the block may have to be checked. look for discolored oil and bubbles in the antifreeze. also make sure the fan shroud is still on.
anyway, hope this helps some, its the best i know. my supra overheated several years ago, i had no idea why, it was out of the blue, gaskets had went. i replaced them with steel reinforced gaskets and increased the torque settings.
ghost88 is offline   Reply With Quote
