I definitely suggest you don't use a wire wheel. Just use a blade scraper to get the stuff off. I believe they have a gasket removing liquid also, you let it soak and it makes removing it easier. I removed all my gasket material with a scraper blade. You want to be extremely careful with air tools as it could make the surface uneven without being able to see it.
