Old 08-04-2005, 09:35 AM   #4
ddmcse
ddmcse's Avatar
master or slave clutch cylinder is leaking . you are low on fluid check it . check the floor by the pedal for signs of leaking fluid .
you can play the fill it up game for a while but you'll get caught in the end .
most recommend replacing both master and slave
i replaced just the master on mine a few years ago ..
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
