Well I run the Lexus AFM/ 550cc injector mod and couldnt be happier. Only problem is that if your getting that code is, since you have to use the housing (the black electronic peice on top.) from the original Supra AFM, your gunna have to buy that too since that is most likely the problem currently.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
