if you want a dependable and much more powerful engine the 1jz-gte is a fantastic candidate.the 7m's either turbo or not cannot hold a candle to the durrability and performance the 1jz.if you are going to do a seriose swap in the future,make it worth yout time and money.i have done so because i got tired of the 7m run around,and let me tell you it is worth every hard earned cent i spent and worth all the blood and sweat also.of course it is alot more involved of a swap.i know everything about what is entailed in a 1jz-gte swap because i've been there.if you get going in that dirrection let me know and i'll help you any way i can.you say lexus stuf is more previlent,your in luck because the 1j was put in many toyota soarers ,lexus sc300,they are the same thing.yep all that heat will sap yer engine power,bummer.hope this helps.
