hopefully your good with a test light or power probe....
first check all your fuses
start disconnecting the rear light connectors (the main harness, where all the wires go into) unplug it and try the signals... see if the left and right are still going at the same time (judging by the front markers) do that also for the other side.... maybe your shorting inside one of the connectors most likely...
if thats not it, then you gotta start checking wires starting at the lights and make your way to the multifunction switch..... maybe its your switch... see if the switch is sending power to the left and right wires at the same time....
other than that, get a schematic and go to town... hopefully your in a warm climate.... 32degrees here
