Old 12-17-2008, 07:14 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
A couple or things worth checking: Make sure your strobe/timing light is set at zero, some strobes/timing lights have a dial advance feature which need to be set at zero. When you have set the timing at 10? BTDC remove the service wire link E1 & T (TE1) this is the wire you jumped, the timing should increase to about 15 ? if it doesn’t then the jumped wire didn’t make a good contact.
