01-08-2009, 08:45 PM
#8
AEM EMS
This may be an alternative way to modify the socket; I used a hand held angle grinder with the socket clamped in a vice to grind down the socket to the required length. Depending on the thickness of your wrench this should give you just enough room to clear the firewall/bulkhead.
