Check the plug on the ISC, if its loose then it could cause that, but for reference check page 4 of this page http://www.swaqvalley.com/TSRM/03_EM.pdf, it will direct you to the info for checking for not idling correctly. Hopefully it will help you, good luck.
"Stuck in the 80's"
