Did the shims also include spring clips? These clips (2) go into those little holes on top of the pads, look something like wishbones, and work to separate the pad from the rotor when the pressure is off. This also helps eliminate squeaks.
To check the hub bearing, refer to the
MK3 TSRM On-Line
