Ok. Well. I have a few questions actually...here we go.
The first question, how it is answered will determine if you the others questions are even relivant, so if its NO, then dont even worry about the other questions, if it is YES. then proceed.
Question 1: Is it possible to swap a twin turbo/6 speed supra engine of the same year 93-98, easily, into a non-turbo 5 speed/automatic chassis. Will there be any fitment problems?
Question 2: Are the physical body structures the same between a non-turbo and turbo car? Such as motor mount positioning, are they the same? Tranny mout positioning the same? Bracketry and cable lines the same? Routes the same?
Question 3: The rear end between both the turbo and non-turbo, are they similar? Can the non-turbo rear end hold up to a turbo motor? Could the physical non-turbo rear end's housing be used to build a quality rear end for power? Are the driveshafts similar?
Question 4: Does anyone know where there is a blown up turbo or non-turbo supra that is for sale? it CAN need to have work.
