Yes but not for very long because it starts out with a small whine then gets worse. I wouldnt expect that to help because the two times I was able to get the system bleed it worked great until about 15 min later it suddenly starts to whine and foam up. After that happens then it wont bleed at all it just starts to overflow when I turn the wheels. It seemed that by me taking the pump off and the idle control valve off then back on it fixed it momentarily. My first thought is that the line from the reservoir to the pump must be leaking in air but Ive gone over it and everything looks fine and I even put a new rubber hose and o ring on it.
