Open you gas cap and listen to hear if there is a whining sound. If there is a wining sound the pump is running. This is how I usually try to identify a fuel pump problem. If it is wining it could be your fuel filter is clogged, the screen to the fuel pump could also be clogged. Did you replace the screen filter with the new pump?
