Don’t forget you’ll need to set it up again when you reinstall it
Link Unfortunately it’s a sealed unit; to gain access to the PCB inside you will need to partially destroy the clips holding the casing together. Also make sure you locate it properly when you reinstall it on to the throttle body, from memory I think there are some lugs on the throttle butterfly valve shaft that need to be engaged carefully. I didn’t take mine apart I only reset it.
