Old 02-07-2009, 01:44 PM   #3
mirage83
The bolts are available through Toyota, regardless of what some techs told you. I had to buy a replacement set last year. The part # for the bolt is 90110-08009, the spring is 90501-07056, and the retaining clip is 90487-07057, but I would check those with the dealership just to be sure they match.
Oh, and if the housing it bolts into is shot, the number for it is 63245-14020.
Hope that helps get you squared away.
