basically... the heads are identical
the blocks are also the same except it's missing the extra holes for oil return/feed etc for the turbo
pistons are dished for the turbo model
i would expect long blocks aren't too expensive... get the wiring harness, ecu, engine and you should be able to wire it in or get an auto sparky to do it for you
