Old 02-10-2009, 06:33 PM   #148
Spudboy
Spudboy's Avatar
Originally Posted by cincisupra View Post
fixed some if of it..nothing to serious, the head gasket...i know nothing about.... would do it if i could..........im open to any help thats thrown at me
Do a metal HG with ARP head bolts torqued to the ARP specs which is around 80 lb/ft if I'm not mistaken. If you do it yourself, take your time and use the big official shop manual (tsrm). You could (if you're not driving hard and it's a non-turbo) use a stock gasket but use the ARP's with the higher torque. Toyotas original torgue of about 45 lb/ft is not enough.
Check this link...http://www.toyota-supra.info/forums/...-w-pics-2.html
If you find a mechanic you trust (good luck) it may cost about $1,500.00. BE SURE TO CHANGE the EGR cooler gasket and check/machine straight. (Don't know if non-turbos have this) This gasket DOES NOT come with the gasket kit...so order it seperate...DO IT NOW AS YOU CAN'T GET TO IT WITHOUT REMOVING THE HEAD...
