Rebuild issues
I was searching thru the MKIII forum for a solution to the gurgling sound I hear upon start up and initial acceleration. Looks like I need to burp my coolant system.
Anyway, back to your post. I noticed you had no replies. I suggest you do a search in the MKIII forum for a specific problem and see what threads come up. Then, if you can narrow down to a few problems try to re-post and see if you get some answers. I have found the forum has a ton of info if you are persistent. Good Luck!
1988 MK3 Supra; 7M-GE; Automatic; Sport Roof; Factory Original
