A couple questions
I just wanted to verify if this method works for testing the clutch. A friend told me to put the car in 4th when the car is at a stop and just let the clutch go if it stalls the clutch is still good but if it doesn't then it's a bad clutch is that true?
Also is the coil connector on a 89 turbo mk3 in the back of the engine behind the valve cover on the right side? and where is the injector fuse located?
Thanks
