Turbo Damage ????
In the process of doing some routine maintenance on a supra that I bought recently, I noticed damaged to the compression fins... how can this happen? It almost looks like an object got in its path. It seems to run clean and smooth on the shaft, but I assume that I should plan to replace, as I assume it is imbalanced and certainly not efficient. Have not pulled, so not sure of the condition of the turbine...
Any suggestions or advice would be appreciated.
If I am going to need replace anyway, should I plan to go to a T4? What other mods would I have to do at the same time.
New Supra Owner, 1988 5spd Turbo, minimal mods - Black Stagger Wheels Rear 225/45/18 on 18x8, Front 215/40/17 on 17x7.5. Aluminum cooler to TB pipe with SQV BOV, SS Turbo Intake with HV MAF Filter Adp.
Tunes - Kenwood Deck Driving Kenwood 1200W 2CH / Sony 1000W 2CH, Kenwood 750W Class D Mono, Rockford Fosgate 500W Mono. Amps Driving (4) 4.5 140w, (2) 6.25 200w, (2) 6x9 225w, (2) JL 10's and (1) JL 8... Yea its loud enough
Reason: mistake in part refferring to
