Old 02-16-2009, 08:20 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Turbo 7M-GTE Coil Pack, Located on top of the cam covers at the front, underneath a black plastic vented cover where the oil filler cap protrudes from . You cant miss it says turbo in red lettering. I assume your intentions are to use this to reconnect the HT leads (wires) after you have finished your compression check on the engine. No 1 connects to the front spark plug No 6 to the rear plug.
