Old 02-24-2009, 03:08 PM   #1
georides
georides's Avatar
georides is on a distinguished road
Default Bad Proportioning Valve?
Hello there from New Jersey, USA
We were gifted a 1987 Supra Automatic non-turbo to resurrect, we've done a solid "tune-up", new starter, fluids, etc. problem now is the brakes.
On inspect the front pads were toast, while the rear pads were still thick, we got new rotors and pads in the front, and refinished the rears.
Did a line flush, but rear bleeders keep spitting out bubbles, pedal feels like air in the system until front pads engage (front calipers bled fine).
I would assume this is proportioning valve problem, we're going to disconnect it today and see if we can unscrew the valve on the bottom.
if our inspection cleaning makes no changes What would you think about just bypassing this valve with some new line splices?
georides is offline   Reply With Quote
