Help for auto trans problem
I have a 1987 toyota supra, turbo with a 340E trans. Problem is it shifts from first to fourth instead of first to second. Overdrive light gives a malfunction code of 63, which indicates a bad number two shift solenoid. Since the number one and number two solenoids are the same part number, I need a picture that shows me which is the number two. I also would like to know if I have to remove the valve body to replace this.
If any one can help I would appreciate it!
Thanks
Fullon
