No fuel need help
I'am a rookie on the 2jzgte I cannot get my car to start the injectors will not turn on. I have a new fuel pump and it stops at injectors. I tried getting the code or number of mil blinks and when i connect terminals it continuosly blinks and does not stop blinking could it be the ecu. I could really use some input on what to check or replace to figure out the problem I have learned alot about this motor but not enough since I started putting it back together i'm at a dead end if anybody could give me some advice I would appreciate it
1993 mk4 tt automatic. It was stripped of the turbo system and alot of other stuff with supposedly a blown motor turned out to be a head gasket . I have it all put back together and I'm having an issue won't start
