Originally Posted by E-ROCK
I'am a rookie on the 2jzgte I cannot get my car to start the injectors will not turn on. I have a new fuel pump and it stops at injectors. I tried getting the code or number of mil blinks and when i connect terminals it continuosly blinks and does not stop blinking could it be the ecu. I could really use some input on what to check or replace to figure out the problem I have learned alot about this motor but not enough since I started putting it back together i'm at a dead end if anybody could give me some advice I would appreciate it
Is there any pattern to the continuous blinking...are there any slight pauses at all in the pattern?
Please refer to this tech article:
MKIV.COM
Note: Your injectors go through a resistor pack and (although rare) that could also be one of the possible problems.
