First, you are far better off buying a engine/transmission whichever you need to get, than to convert a engine that was not setup for the application you impose to it. Second, you need to state your mechanical skills, do you think you can hoist a 900 pound block of metal into the air, and replace it. Third, if you don't have the facilities to do the work yourself, then hire it done, you most likely will double or even triple your costs for this. Fourth, you should not attempt it, if you know nothing of what you are getting into.
