yea you are better off getting a stock turbo 7mgte, if thats the route you are going to go, because its alot of work to turn an n/a into a turbo, and if you dont have the skills necisary to do the swap, your lookin at around anywhere from 400-700 to have someone swap it in, and since the trannys are different lengths, you will have to change the drive shaft to one out of an r154. start getting some money together,
