Originally Posted by E-ROCK
I have bought the repair manuel from the dealership tis two books one for mechanical one one for body / electrical . I came across a couplke things that it said it would turn off injectors for fail safe mode like an air leak in intercooler couple other ones i went threw those but my light will not stop blinking i couldnt find anything in book that says that ther is a continuos blinking light. The one last thing it said that control baro censor that is in computer controls the injectors but I dont know how to check computer to see if there is a signal apprieciate the help
A continuous blinking light means there is no code stored in the ecu. You'll need to troubleshoot the fuel problem via standard steps. For example:
1) Do you have fuel pressure?
2) Is your injector pulse from the ecu getting to your resistor pack?
3) Is the pulse getting from your resistor pack to the injector?
4) Does the injector have a good ground?
...etc. Iirc, the engine TSRM has all of these troubleshooting steps for fuel.
