Thanks for the info Quint, I really appreciate it. The website is helpful as well.
Do you know if a gearbox from a 2wd truck would work, like a 2wd Hilux/Tacoma?
Do you know if the Cressida is the only car that had the short 18" shifter to bellhousing spacing?
I'm running a Fidanza flywheel made for the Jag. I imagine I'll just have to have the Toyota pressure plate re-drilled by my local machine shop to match up to the studs and bolt holes on the Fidanza flywheel. Hopefully it isn't any more complex than that.
