Old 03-19-2009, 05:21 PM   #7
btwilson86
Super Moderator
btwilson86's Avatar
All belts stretch over time, which is why they have scheduled intervals to change them. Seeing as how you're at 130,000 miles on the original belt, I'd say you should change it. If you're not getting it to budge with a long breaker bar, then you probably should soak it liberally with some penetrating fluid. Maybe you can try using the "starter bump" method next time you try to get it off. I've never removed mine, so unfortunately I can't offer you any real help in removing it.
Oh, and make sure you replace your tensioner with your belt
