Old 03-29-2009, 05:06 AM   #1
jza80rz
jza80rz is on a distinguished road
Default engine warning light :(
i too have the same problem, but not only does that light go on but others aswell including oil light, battery light, i think heating? (looks like a cat with heat waves coming out) and i think rear lights..
first of its very weird because i know the car has been serviced reguarly by toyota, i recently bought the car and yeh shes mechanically A1 besides the lights which only come on every now and again..
i was browsing around and came across this.. http://www.mkiv.com/techarticles/eng...bd1_codes.html
"The ECM stores the code(s) until it is cleared by removing the EFI No. 1 fuse with the ignition switch off."
First off i know that oil is fresh as i change it every 3000kms with motul chono v, and replace the oil filter and use e30 engine treatment. and i know the oil is at the right level.
next is if that cat symbol with the heatwaves means coolant/overheating thats impossible because the cars temp gauge does not show any overheating, however though when i do turn the car of i hear gargling sounds.. coming from the coolant pipes. if anyone has something to add on that please do.
with the rear light symbol, i guess thats my rear lights which work well except for the small centre brake light with the leds, i have about 4 which arnt working but im pretty sure that shouldnt show up as a fault?
and battery, car starts up fine everytime, alternator is good.. though i do have a sub connected (previous owners) maybe some faulty wiring.
Ok, this is what im planning to do..
oil change & new oil filter plus e30 engine treatment and oil flush
coolant flush, then coolant chnage and bleed out any bubbles
spark plugs iridium ngk's im thinking BKR6EIX-11
flush brake fluid via bleeding, then new dot 4 fluid
transmission oil change castrol vmx, with nulon g70 treatment additive
and last but not least air filter clean
after all this i plan to disconnect the battery, then reconnect it start her take her for a spin.. and if i still get the warning lights ill refer to "The ECM stores the code(s) until it is cleared by removing the EFI No. 1 fuse with the ignition switch off." and give that a go.. if the lights still come on im screwed guys
PLEASE DO add any suggestions or comments!
jza80rz is offline   Reply With Quote
