every thing is hooked up, iam running a maf sensor off my other 91 supra turbo. You said my map sensor? I did not think they (supras) had map sensors? The turbo is the stock turbo with a diffrent comp/wheel, It sounds like it is moving way more air then stock. The guage may be wrong but I know it is not pulling as hard as it used to. It also seems like above 5500rpm boost psi stays at 4psi but does not pull hard like early in rpm range?
4" Turbo back/maft-pro powered/70mm TC turbo/JE Built forged motor
