Project has been stalled for about a week now. Been rainy and cold. Had some other things needing to be done too. Going to purchase 2, 1/4 pieces of steel, 8 X 8 1/2 inchs. Drill out the 4 indentions on the stock frame mounts. Then, set the pieces of steel on the mounts and cut a groove for the steering shaft on the drivers side. Drill holes through the steel to align with the frame mounts holes. The steel will also span the distance to the frame rails and will be welded on there as well. The engine mounts will rest on each of the steel braces. Sooooo..... the engine needs to come back out, again. *Sigh*
VT247
