Test for voltage at the coil. If there is no voltage going in to the coil, there obviously won't be any spark coming out. Pull off the distributor cap, is the rotor in place?
Best way to test for spark is to pull out a spark plug, insert spark plug into mouth with plug wire still connected, have a friend turn over the engine. If you spit the spark plug out, you got spark. lol
VT247
